Search the Community
Showing results for tags 'fault codes'.
  • Search By Tags
  • Search By Author
Content Type
    • New Members Introductions
    • Vauxhall Owners Lounge
  • Vauxhall Models
    • Vauxhall Corsa Club
    • Vauxhall Astra Club
    • Vauxhall Vectra Club
    • Vauxhall Insignia Club
    • Vauxhall Meriva Club
    • Vauxhall Zafira Club
    • Vauxhall Mokka Club
    • Vauxhall Antara Club
    • Vauxhall Electric Club
    • Vauxhall Classics
  • Vauxhall General
    • Vauxhall Meets
  • Traders and Supporters
  • Vauxhall Marketplace
    • Vauxhall's For Sale
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
ICQ
Yahoo
Jabber
Skype
Interests
Found 1 result
  1. Hi everyone I have an insignia 2.0d, I have issues regarding starting, it won't. I have gotten the following codes from my scanner P2282 (I replaced MAF sensor),P0101, P0403,P0193,P0113,P2100,P0344,P0016(REPLACED CAM AND CRANK SENSORS), P0336. I need advice as to which if any of these faults are related or 1 or more being a consequence of each other if that makes sense. I know my fuel filter needs replacing and I also think my timing belt also needs replacing. The car rotates but is not firing at all not even a whimper I just run the battery flat. My intention is to change the timing belt and fuel filter. Is this the best place to start and take it from there. I did have the dreaded low oil pressure problem but fixed that by replacing the pickup seal. Any help at all would be appreciated. Thank you.
