when openining roof i get the bleeps .engine on hand brake on out of gear lugage storage back catches down windows drop has should no codes or warnings battery ok fluid ok will look at fuses and disconnect battery.any ideas ?with there being no codes on do i need to check sensors with elec screw driver tester ie in doors .left side of luggage .handbrake etc ? worked fine yesterday could be intermittent am i missing something.
