Sheelaghm Posted January 23, 2018 Posted January 23, 2018 Hi all, bought an 09 Tigra a few months ago which I really love, however, sometimes when I turn the key in the ignition the alarm goes off. No matter what I do (open and close door, press various key fob buttons, turn ignition on and off again, vacated the car and locked door with fob) nothing interrupts the alarm. I just have to wait until it stops by itself and sometimes it happens a second time. Haven't taken it to the garage as it only does it every 1 in 12 times (approx) and not sure what they can do if the car isn't exhibiting the problem when I go there. At first I thought it was after closing the boot but it's happening when I haven't used the boot. Luckily I don't leave my house at unsociable hours as I would have rather peeved neighbours. Any Tigra owners had a similar problem? If so, advice would be very much appreciated. Sheelagh :) Quote
Vauxhall Owners Club Posted January 23, 2018 Posted January 23, 2018 Hi Sheelagh...welcome to the Forum It sounds like a battery connection fault...corroded terminals, loose connections and / or poor earth connections to the chassis / body. Definitely a good place to start and work back from there. Let us know how you get on Cheers, Trevor Quote
Sheelaghm Posted January 23, 2018 Author Posted January 23, 2018 Hi Trevor, thanks for taking the time to reply to my post. I’m not adverse to getting under the bonnet, so will certainly take a look at the connections. Of course I won’t know straight away as it doesn’t always play up. Will let you know either way. Thanks again Regards Sheelagh Quote
Sheelaghm Posted March 6, 2018 Author Posted March 6, 2018 Hello again Trevor, tried unplugging as suggested above. Left overnight and wired back up in the morning. Alarm not fixed and car was stuck in 4th. How I laughed (not). Well after wiping away the tears from my initial panic, tried undoing terminals and replacing again. 4th gear issue resolved, phew. But back to square one re the alarm. Going into garage tomorrow for a diagnostic as also issue with windows not returning to closed position after opening roof, which is weird as all works ok when closing roof and windows work fine normally. Have bought myself a Vaux-com which arrived today but is refusing to load onto windows 10. Thinking of getting a horse n cart.I can manage hay and water!!! Thanks Sheelagh Quote
arwyn Posted August 12, 2024 Posted August 12, 2024 The alarm on my 09 tigra won't go off whatever you do apart from taking the fuse out so at a loss everything else works has anyone ideas apart from leaving the fuse out ???? Quote
FRONTERATECH Posted August 13, 2024 Posted August 13, 2024 (edited) power sounder under wing battery dead will bring it on has its own battery link to catalog and part number https://catcar.info/opel/?lang=en&l=bW9kZWx0eXBlPT1YMDR8fG1jb2RlPT1PUE18fGxhbmc9PUdCfHxzdD09NTB8fHN0cz09eyIxMCI6Ik1vZGVsIiwiMjAiOiJPcGVsICBUSUdSQS1CICggMjAwNCAtICkiLCIzMCI6IlAgRUxFQ1RSSUNBTCIsIjQwIjoiIDE2IEJPRFkiLCI1MCI6IjUuQU5USS1USEVGVCBXQVJOSU5HIFNZU1RFTSJ9fHxzY29kZT09UHx8c3Njb2RlPT0gMTZ8fG1uY29kZT09MjJ8fHNtbmNvZGU9PS03fHxpa2V5PT0zOQ%3D%3D Edited August 13, 2024 by FRONTERATECH Quote
