Meaning of P0513 engine trouble code is a kind of powertrain trouble code and theoretically you can drive for a few weeks or even months with a broken MAF sensor. You will notice a decrease in gas mileage and over time the car will eventually start stalling a lot. At a shop, the replacement cost is between $240-$400 depending on the car, but that's usually the cost of parts because the labor is relatively simple.
P0513 Fault Symptoms :
  1. Check engine light comes on
  2. Engine stalling or misfiring
  3. Engine performance issues
  4. Car not starting
If one of these reasons for P0513 code is occuring now you should check P0513 repair processes.
Now don't ask yourself; What should you do with P0513 code ?
The solution is here :
