Stuart Webster Posted September 30, 2018 Posted September 30, 2018 The spanner light won’t go off in my Corsa 1. 3 cdti. I’ve tried new fuel filters ,air flow meter.When you start the engine it’s very fumiy and a tad smokey any ideas thanks Quote
Vauxhall Owners Club Posted October 1, 2018 Posted October 1, 2018 Hi Stuart...welcome to the Forum Sounds like it could be a Service lamp which may need extinguishing if it had a service but wasn't reset...or it needs a service! Diesel engines do tend to over-inject slightly on startup as the fuel isn't completely burnt until cylinder temperatures increase sufficiently...which isn't usually too long afterwards. Check also that the oil is not degraded (see earlier comment on servicing) and that the level isn't dropping. Cheers, Trevor Quote
Stuart Webster Posted October 1, 2018 Author Posted October 1, 2018 Thanks Trevor it has been serviced recently it was about 8 weeks after service that it came on and had it on laptop but no fault codes came up it went off on journey home but came back on next morning thanks Stuart Quote
Vauxhall Owners Club Posted October 3, 2018 Posted October 3, 2018 Sounds like a soft fault....could be an Air Mass Meter not reading accurately and then clears but leaving a historic fault code. I'm sure there must be some trace of it in there somewhere. Did it happen after the service or before...only something may have been disturbed (connection, etc) and causing the lamp to trigger? Quote
Stuart Webster Posted October 3, 2018 Author Posted October 3, 2018 It happened a few weeks after service i have also tried disconnecting the battery but too no avail Quote
Vauxhall Owners Club Posted October 4, 2018 Posted October 4, 2018 can you post up a photo of the lamp? Quote
Stuart Webster Posted October 4, 2018 Author Posted October 4, 2018 Can’t seem to be able to upload photo of light Quote
Stuart Webster Posted October 7, 2018 Author Posted October 7, 2018 I’ve now Scanned for fault codes and code P000E has been found can anyone help with what it means and how to resolve many thanks Stuart Quote
Vauxhall Owners Club Posted October 8, 2018 Posted October 8, 2018 Here is a link with some probable causes....certainly worth looking at the easy ones which shouldn't take long to check https://www.yourmechanic.com/article/p000a-obd-ii-trouble-code-a-camshaft-position-slow-response-bank-1 Quote
