Col4stac Posted December 19, 2018 Posted December 19, 2018 Steering on 2005 vectra gets stiff when wheels are straight almost 2 the point of locking up is this the steering rack knackered or power steering issue Quote
Vauxhall Owners Club Posted December 21, 2018 Posted December 21, 2018 I would look at the Strut Top Mounts as these can cause the issue you are describing. If you raise the front of the car (both sides) and then turn the steering from lock to lock and if it doesn't bind then that is more than likely the problem (since the weight has been taken off the mounts). It will also give you the opportunity to see if there are any other points where the steering in binding Quote
