Hi all, I have a corsa d that has had timing chain failure after 40k. Engine is done for. It's the 998cc ecoflex 3 cylinder version. What I want to know is, what other engines are a straight swap without any additional hassle.
Thanks in Advance.
Hi....welcome to the Forum
To be fair, I'm not entirely sure what else will fit but it may be worth locating a secondhand replacement engine and replacing the timing chain assembly before fitting so that you know it will last more than 40k
