Jack Posted March 6, 2020 Posted March 6, 2020 I was driving my Vauxhall’s Astra excite last night when I stopped at a service station. My car has had no problems before but when I went to get back in the car it wouldn’t start and it came up with CODE68. I managed to get someone to give me a jump start and the car has been fine today? Any ideas on what this could be and whether it will happen again? Quote
AndyR Posted March 8, 2020 Posted March 8, 2020 Hi Jack, and welcome to the site. I have just done a google search on your CODE68, and it states, "Code 68 relates to a power steering fault. As these cars run electronic power steering, a week car battery is a common culprit." This was on a Vauxhall forum, and was mainly Astra's that seem to suffer this issue. I will be keeping an eye on my own Astra. Hope this is helpful. Regards Andy. Quote
Vauxhall Owners Club Posted March 9, 2020 Posted March 9, 2020 Absolutely agree with AndyR diagnosis. Check and replace the vehicle battery and this should cure it Quote
Jack Posted March 9, 2020 Author Posted March 9, 2020 Perfect. Since I managed to jump start the car I haven’t had the issue since. Should I still replace it or should I wait and see if the problem occurs again? Quote
Vauxhall Owners Club Posted March 11, 2020 Posted March 11, 2020 Thanks for the feedback Jack, it always helps to know if its cure the issue for others to know the solution Quote
jayjay Posted December 18, 2021 Posted December 18, 2021 (edited) my vauxhall mariva 60 plate , has code 68 also but the car starts perfect , could the battery still be the culprit? just hoping its not the more expensive option of a new steering pump Edited December 18, 2021 by jayjay Quote
AndyR Posted December 19, 2021 Posted December 19, 2021 Hi jayjay, it might be worth getting the battery checked to see if its losing charge. If it is not, then it may well be the steering pump. Probably not something you'd want to hear this close to xmas though. 1 Quote
Vauxhall Owners Club Posted December 22, 2021 Posted December 22, 2021 Agree with AndyR especially as the mornings are getting a lot colder now, this is when the battery will deliver the power to where it is needed most and some sub-systems fall a little further down the scale Quote
Yates Posted January 11, 2022 Posted January 11, 2022 I have a code 68 on 2013 astra. The steering went stiff. As it was original battery I have changed this. I have restarted car and steering was fine but 5 mins later fault popped backup and steering gone stiff? Any suggestions Quote
AndyR Posted January 12, 2022 Posted January 12, 2022 Hi Yates, code 68 does relate to power steering fault, which usually means battery doesn't have enough juice for steering to operate so well. The steering is electric, so hence battery would cause this. As you have changed the battery, it could be that the alternator isn't putting enough charge back in to the battery whilst running, which then means battery isn't powerful enough to do steering again. A vicious circle, but it might pay to get the alternator checked out too. Hope this helps. Regards AndyR. Quote
BaronXL Posted December 14, 2022 Posted December 14, 2022 On 12/22/2021 at 9:07 AM, Vauxhall Owners Club said: Agree with AndyR especially as the mornings are getting a lot colder now, this is when the battery will deliver the power to where it is needed most and some sub-systems fall a little further down the scale I have vauxhall meriva 15 just as I finished my night shift today at the hospital I started my car and my steering was stiff with the steering sign and service light sign showing on my dashboard. Then I had to call AA to help me out as I was waiting for them after 2hrs of wait I went back to my car started it and everything disappeared the steering came back to normal..so my question is dose it mean its my battery that was low then ? Quote
AndyR Posted December 14, 2022 Posted December 14, 2022 That is quite possible, with the car being cold after your shift, it would take a bit more to start, and that could've drained the battery down. And after sitting a couple of hours it may have had enough to start and clear the fault. Might pay to get battery checked in case it's not charging as well as it should. AndyR Quote
PhilS Posted December 13, 2023 Posted December 13, 2023 (edited) Hi I have a 2013 Astra J active as above I have code 68. I have a battery read of 12.3v when the ignition is off. Is that too low. The car starts first time every time. I have tried disconnecting/connecting the battery no luck there. When the car is started shows charging at 15+v (if it shows charging at that rate isnt it enough power for the power steering to work.) Edited December 13, 2023 by PhilS More info Quote
AMG Posted December 19, 2023 Posted December 19, 2023 I have a 2014 Adam. Got in my car tonight to go shopping and it wouldn’t start was just flickering and got the code 68. Really don’t need this right before Christmas! Now worried about the costs for the garage to come and get it from my house on top of what may be wrong. It’s recently just passed its MOT. My car also has VERY low mileage so I’m hoping it’s nothing major. My bf thinks it could be the alternator. When he checked it, it briefly started up. But he decided to switch it off and back on to double check and it was just doing the same thing again. Quote
Claire Posted November 1, 2024 Posted November 1, 2024 I have a 2014 vauxhall astra car has been running fine. Then today code 68 came up and the EPS dash light. After driving home which took 5 mins I turned the engine off and left for 5 minutes when I started the car the lights didn't come back so I drove round the block and it seemed fine. On the 5 minute journey when the lights were on my steering did feel a bit loose. Any ideas?? Quote
Vauxhall Owners Club Posted November 7, 2024 Posted November 7, 2024 Check your battery (Halfords do a free test) and replace if necessary There is always more of a load on batteries during the colder weather Quote
