Nick Posted April 30, 2020 Posted April 30, 2020 Hi all, due to lock down my battery is completely dead.Going to be putting a new one on in a couple of days. Is it just simple swap or any circuit issues issues I should know about. Quote
Vauxhall Owners Club Posted May 1, 2020 Posted May 1, 2020 The battery swap should be okay to retain settings but if in doubt you can use another battery to connect via wires to put a charge through the leads whilst disconnected. There is a special tool for this but you can use wires for cheaper option https://www.ebay.co.uk/itm/Draper-12V-Car-Vehicle-Radio-Code-Clock-Memory-Saver-12V-Socket-Battery-Changing/133344192488?hash=item1f0beee7e8:g:3hMAAOSwOGleVSSs Quote
Nick Posted May 1, 2020 Author Posted May 1, 2020 Thanks a lot. .just changed it,feel like I got away with it. Quote
Vauxhall Owners Club Posted May 4, 2020 Posted May 4, 2020 Good to hear and thanks for letting us know the outcome Quote
Nick Posted May 4, 2020 Author Posted May 4, 2020 Thanks..update,I did have code 59 which is "open and close drivers window and had to reset the idle,simple hold revs at 2500 three times. Quote
Vauxhall Owners Club Posted May 5, 2020 Posted May 5, 2020 That's not too bad then and hope the battery has improved things Quote
