Morning,
I need my Ignition coil changed but i just want to confirm what it is. is the ignition coil just a spark plug? and if so is it in the same place as all the other spark plugs?
Thanks
Ellis
If an ignition coil needs replacing then it is a good idea to replace the plug at the same time.
Usually, coils fail if the plug gap is too large and / or overtightened which will increase the gap.
The coil has to work harder and fails sooner
