Hi gents,
I am on here seeking some advice if you can. I have a Vauxhall Insignia hatchback, 2.0 diesel 160Bhp, 2011, Elite. I have the headlights with the DRL (Daylight Running Lights) and the cornering lights inside the same headlamp. I also have the Bi Xenon set up in the headlamp unit.
A month ago I noticed the lenses were both effected by condensation inside the lenses. I researched YouTube and decided to have a go at removing the condensation. New lights are £1300 each plus £300 each for a ballast. Thats £3200 plus fitting!! The car is worth £2500. I love this car and have had it for over 9 years and dont want to get rid of it. The lights were working fine before I fiddled with them!
I took both light units out, removed bulbs and blasted my hairdryer in them and cleared the condensation. Resealed the edges with clear mastic. Checked both ballasts and one was full of water and had green corroded pins. I bought two new ballasts that had the same serial numbers from Ebay, and paid £50 for the two. Apart from the ballasts being a newer revised model all the other info on the back was the same as the old ballasts. I contacted Hella who make the ballasts and they said a revision number wouldnt make a difference as long as the serial or part number was the same. I am assuming the ballasts are working but that is an assumption.
Put everything back together. This is when the problems started. I will list what does and doesnt work.
1. Right headlamp works fine for everything.
2. Nearside dipped beam doesnt work
3. Nearside main beam doesnt work.
4. Nearside cornering lights work
5. Nearside Daylight Running Lights work.
6. When i turn all lights off and pull the flash. I get a mini second of full beam on the drivers side, nothing on the nearside and then both sides are off. If i turn the lights onto constant (not auto) then do a flash, the drivers side main beam activates fine. Release the stick and light goes back to dipped beam. Turn on main beam and drivers side works fine. It feels like not enough electricity is getting into the bulbs to hold the flash.
I changed all bulbs and no difference. Checked all fuses and everything seems fine. I am assuming I am getting electricity to the nearside as the DRL and cornering light works.
Unfortunately i threw the old ballasts away too early so cant put them back on to test if this makes the lights work.
This is my problem, any thoughts at all on the matter....apart from dont fiddle if it works fine.
I would like to replace the lights with new lights and lovely fresh lenses but not at nearly £3000. Has anyone swapped the elite lights for standard xenon lights. Could I do this or would I have to put in a different loom etc. Thats a bit above my car maintenance skills to be honest. Is there a simple fix that I am missing.
If you can help that would be great. I popped into two garages and they had a look and couldnt fix it but neither had a really good try. They swapped bulbs and a few basic things. The warning I have on the computer is "check nearside and offside dipped beam".
Many regards
I recently encountered a similar issue with a Honda and this came down to the fact that I fitted cheap (Chinese) bulbs and igniters....massive mistake.
Fitted quality (but a lot more expensive) components and problem solved.
Also, another issue I had was that the fitment was not as precise connection as the better quality component and didn't alway make good contact.
It is worth double checking connection, etc but also check any earth leads (which will be close by and connected to the bodywork.
If in doubt, run additional earth cables to the light units to ensure that the current circulates effectively.
  • 2 years later...
Hi did you resolve this with your ELITE insignia?
Mine is doing the same. Lights condensated no DRL or anything currently working. Well just 1 DRL. No high beem either.
I feel its the ballasts.  I will order 2 and 2 bulbs.
How easy is it to remove headlight?
Cheers Darren
  • 1 year later...
Posted (edited)
Hi I hope this might help,.I've got a 2014 insignia elite and found myself was having peoplems with the driver side headlight. The headlight was full of water and had a lot of condensation . After alot of visiting garages, scrap yards etc.. i stumped across this guy  based in Redditch.
We had a long  conversation and he explained everything that i was experiencing and what I can make out Vauxhall have been baught out by Citroën and Peugeot ? The headlight manufacturer was Hellar who supplied Vauxhall, because of this take over hellar was no longer suppling these headlights.
This guy has now got hella suppling him these headlight with a complete new seal which was the problem that everyone was having and he fits them, he has the softwear to re program each light he fits. These lights are so rear and do costs especially the drivers side. (950.00)
He fitted mine today and was very through , he also said to be aware of cheep light from Ebay as  they are not true Xenon lights and wont work.
This guy was very honest and just wanted to help after spending time with him things became a lot clearer.
I hope this helps .
Edited by malcolm64
