zbroadbent12 Posted February 13, 2021 Posted February 13, 2021 Hello.. Hoping someone could help I got a Vauxhall insignia 1.8 petrol I got a problem where it hits temperature it start hunting/misfiring it runs perfect to it hit temperature Don’t know if related or not But when you removed dip stick or oil filter cap it trying to stuck air in All started from a map sensor what has now Been changed Quote
Vauxhall Owners Club Posted February 15, 2021 Posted February 15, 2021 If is occurs at a specific temperature then I would advise changing the Coolant Temperature Sensor as this would cause similar issues at a specific temperature. Not too expensive to replace and should be an easy enough job to do Quote
