Hi, my cooling fan is starting up just shortly after I start the car from cold. I don't have any warning lights on the dash. The fan goes off once Car is up to temperature.
I have a 1.2 2014 corsa D
Any help would be appreciated
Chris
Hi Chris
I would say it is either the Air Conditioning on and running the fan and if not equipped then it is more than likely a faulty Coolant Temperature Sensor / Sender providing incorrect information causing the fan to believe it is warmer than it actually is
Yes you are spot on,  coolant temperature sensor on  the block it was. Note to self though drain coolant off first 🤪
