Speedbird Posted May 11, 2021 Posted May 11, 2021 Hi All, My son has a 2005 1.0 Corsa C, This car is just turning over but not firing up. Ive been told its a body module problem which apparently you get with the dials. Ive had the ecu checked and that apparently is ok. i have been told this body module problem is a common fault but to be honest not sure where to start. Key reprogramming man has been out and told me this is what i need. Can anyone help as i had a full head of hair at the start of this.. lol. Hoping anyone can help With Thanks Rhys Quote
Vauxhall Owners Club Posted May 18, 2021 Posted May 18, 2021 Hi Rhys.....welcome to the Club If the car is turning over then it is not an immobiliser fault which I believe the CanBus gateway (instrument panel and BCM) would be affected by. Chances are it is more likely to the Crankshaft or Camshaft sensor at fault. Also, check to see the camshaft is turning and that the belt/chain has not snapped Quote
