Adam L Posted June 6, 2021 Posted June 6, 2021 Hi everyone, I have issue with the auto feature on my 2011 Insignia. When lights are selected on auto I get an error message for which ever the car is trying to run i.e. check right sidelight/check right dipped beam. This only happens when lights are on auto and only the right unit. When i manually select sidelight or dipped beam they both work. Any ideas? Thanks in advance Quote
Vauxhall Owners Club Posted June 8, 2021 Posted June 8, 2021 It may well be the bulb at fault as it will look for a resistance and could be corrosion causing it to read slightly high. Worth removing the bulbs to inspect them Quote
