Gavlar2021 Posted August 15, 2021 Posted August 15, 2021 When I turn the engine off above the radiator is a small unit with three pipes two rubber one metal it go's tick tick tick then it sounds like a ships horn sort ov noise Quote
Vauxhall Owners Club Posted August 23, 2021 Posted August 23, 2021 Sounds like it could be a PCV valve or similar which is releasing pressure or resetting. If it is making that sort of noise then if one of the lines is running pressureĀ or vacuum and is split then it can create this noise Carefully examine the hoses going to the unit Quote
