Hello, Looking for some Knowledge and/or Experience .
In the flash floods last week my Corsa D got flooded, I un-did the battery - took off the air filter and dried the area- took out the plugs- undid the fuel relay- i then proceeded to crank it over to chuck out water in the cylinder's and all was fine for 10s and then turning over another 5 seconds into it there was a scratch then on the next crank over half a second or so a clunk.
checked under the car and found it had pooped, i found several bits of metal on the floor and then checked where it was from, on inspection i found a 2p size hole just under the manifold.
I would rather fix  the car if it is possible but im awear its scrap unless its possible that i can repair it. Its not the work i have an issue with as i have worked on car's before how ever this is a first with water damage. Could you advise me  on tips and know how in this situation ?
Thank you in advance
  • 1 month later...
