Morning All,
i have a astra J 2011 Estate 1.7cdti - been driving it a little while now and since driving it every now and again i am unable to select a gear. i pop the clutch down go to select and it feels like it wont go in. been under the bonnet and moved the clutch arm on top of the gearbear box by hand which moves the pedal internally and then i am able to select gears again. it has only happened twice but want to catch it and resolve it early.
has anyone had this issue before?? - i had thought about trying the below but any advice would be greatly appreciated
  • Re bleed system - i know its connected to the brake lines so could still have air in system?
  • replace master cylinder?
  • clutch pedal return spring?
Cheers
Wheels
Edit - sorry dont mean clutch arm. Mean gear selector on the very top of the box
