Posted (edited)
Hi all
My engine management light keeps coming on after 10 mins driving I have had theAA twice and fitted a new cam sensor and crank shaft sensor as per the diognosis but the light has come on again I can’t keep fitting parts can anyone help please car is a omega 2.2 53 plate
thank you
Edited by Timmyb
Forgot
Not sure if the engine goes into limp mode but if not then I would probably ignore the lamp if it is not affecting the performance
There was an issue I recall from many years ago and the sensor cable was wrapped in tin foil and connected to earth so if gave a shield from any electrical interference that could create 'noise' in the sensor readings
