Bigboy01 Posted January 29, 2022 Posted January 29, 2022 Hey everybody, I have a 2008 1.8 vvt sri, when been standing a while and you start up, a split second rattle from the cam pulleys occurs, I have heard about oil filters with a non return valve in to help stop this, have any of you heard about this? If so where can I get one from? Or if there are any other mods to help stop this. Regards Lee Quote
randy blackman Posted August 9, 2022 Posted August 9, 2022 just change the pulley, i had the same problem with mine, we couldn't figure out where the noise was coming from till it was to late and had to change the engine, i was told it was water pump to bottom end knocking,then the unthinkable happen on m/way .smoke was coming out the back like a war plane just being shot down oil light on, however it did carry 30+ miles to service station,check the oil not a drop in it. top it back up car went to Manchester and back to birmingham all because of the pulley ,valves was opening or closing as should. 1 Quote
