Hi everyone ,
I have a Zafira 1.9 ctdi 150. I’m not sure if I have a thermostat problem . It seems to be sitting around 78c. It does get upto 84 at its highest but then goes back down to 78. The coolant pipe stays cold until 78 though. It doesn’t give any codes though or warning lights . Can anyone help please ?
Hi....welcome to the Club
88 degrees Centigrade is the normal opening temperature for the thermostat
Anything up and around that figure for an engine operating temperature is fine.
If it is a lower coolant pipe then that is also fine as it is circulating in cold air and lower part of radiator.
If the hose feels soft (e.g not slightly compressed with coolant) within it the maybe you have air trapped in the system
Hi, thankyou for the reply . Yeah the bottom pipe stays cold until around 78c like I’ve said , so you think it might be ok?  I did a flush on it this weekend but it’s made no difference. MAybe I’m just overthinking it ?only reason I checked was I had intermittent cold air in the heaters but I topped the coolant up and it’s been fine . How could I go about trying to get air out of the system ?
