PeterC Posted August 1, 2022 Share Posted August 1, 2022 So it seems I need a new Brake Master Cylinder. If I push gently the pedal goes all the way to the floor !. If i stab the pedal the car will stop but its alarmingly poor compared to a healthy newer car. New ones all seem to be out of stock and a lot of searches throw up ones that turn out to be incompatible. I also keep getting to LHD versions or non-ABS versions. When I do get to a correct (maybe) one it is out of stock. I get the impression these are not easy to repair but some say they can be done at a specialist - any pointers ?. Quote Link to comment Share on other sites More sharing options...
Vauxhall Owners Club Posted August 10, 2022 Share Posted August 10, 2022 Sounds like the fluid is leaking past the seals in the master cylinder (like internal bleeding so it doesn't leak out but the pressure just drops as fluid leaking between the seals) I would be tempted to install a repair kit (seals, etc) in the master cylinder as they are rebuildable from memory A very easy job to do just ensure you soak the new seals in fresh brake fluid overnight and try to clean up the bore first Quote Link to comment Share on other sites More sharing options...
PeterC Posted September 27, 2022 Author Share Posted September 27, 2022 (edited) Thanks. The kits seem to be less than £20. The garage I am using don't like refurbing BUT I do. Anyway - worth a try. Currently on the back burner as the garage have space and a Mustang to finish rebuilding while i research. Worry is the locking wheel nut key broke on the last wheel and a caliper bleed nipple has snapped, I had a spare caliper but on dismantling the casing broke apparently. Bit of a slow reply from me as I lost my notes on how to log in !. Edited September 27, 2022 by PeterC Spelling and Added info. Quote Link to comment Share on other sites More sharing options...
Vauxhall Owners Club Posted October 17, 2022 Share Posted October 17, 2022 Any update on how its all going? Quote Link to comment Share on other sites More sharing options...
PeterC Posted November 1, 2022 Author Share Posted November 1, 2022 On 10/17/2022 at 9:13 AM, Vauxhall Owners Club said: Any update on how its all going? I have been a bit pre-occupied and the garage seem to still be busy. There is a firm in Anglia that can refurb for about £150 plus carriage. But I would love to try the kit first. I need to get back on it at least to check the battery. But at the moment my Vectra is unwell. 1 Quote Link to comment Share on other sites More sharing options...
