It sounds like the tyres may have been swapped around recently and some may be slightly below pressure.
Try inflating all tyres to slightly above the recommended pressure (you can always let some out later if required) and go for a drive to see if that makes any difference.
If a low tyre pressure has been registered then the headlamp alignment (via the suspension sensors) would recognise a slight deviation in vehicle height on one side, e.g. if the car has been driven on a flat tyre or sat in a driveway/forecourt with a flat tyre for a while)
