Artizan15 Posted January 24, 2023 Posted January 24, 2023 New to the forum. I have just purchased a Grandland X and want to install a Dashcam. I have a hard wire kit, . However I'm wondering which fuse to Number to use so that the dashcam turns off when the ignition does. I would also like to change the wallpaper the on the Infotainment System. I have seen how this is done on a Vauxhall Corsa Infolink system and wondered if anyone else had tried this? Any Assistance gratefully received Mark Quote
Vauxhall Owners Club Posted January 25, 2023 Posted January 25, 2023 Not sure of which exact fuse to tap into but have done this job before on a Honda and measured the volts to see which fuse is live and if it goes off when the ignition is switched off....seemed to be completely different to the one I though it would be (fusebox cover description)....best to measure as you will definitely know which one is best. Quote
