Hi All,
So my oil switch has started leaking, and I’m at a loss. It’s not the first time and has previously been an easy fix but I’m struggling to find the part. All listings on eBay state a 24mm spanner size and M10 thread, 13mm long. Yet the one currently fitted to my vehicle is a 22mm spanner, still has an M10 thread but it’s only 10mm long. Does anyone have any know what’s going on here or come across the same problem and solved it? Also Euros and GSF don’t seem to stock any switches or sensors for a corsa????
Many Thanks
I recently managed to get one from a local parts factors (Jayar) and although it was a slightly different design and measurements as you have mentioned it did the job nicely.
As long as the M10 fitting (tapered as I remember) is the same and the pressure reading limit stamped on it then its fine
