Shaun Higgins Posted May 24, 2023 Posted May 24, 2023 Hi there, Has anyone had experience with no power to the washer pump on a 2016 zafira ? I've had the pump out and connected direct to the battery and it's working fine in forward and reverse, there are no fuses blown so I have connected a multi-meter to the supply wires and I'm getting a reading that jumps between 2.7-4.1 volts which I'm guessing is not right. My question is do you think that the control unit around the steering column where the stalk fits into is faulty ? Any advise would be very much appreciated. Thanks Shaun Quote
Vauxhall Owners Club Posted May 29, 2023 Posted May 29, 2023 I would look at the earth to the pump when it is fitted to the vehicle and if not good then fit a substitute earth lead to see if that improves the voltage readings Quote
