Do anyone have any idea why my car battery keeps on dying. I have changed at least 4 batteries within the last 8 months so it’s would be helpful if someone could tell me why
You could have a faulty alternator which is causing the drain or not fully charging the battery
A battery check with heavy duty discharge will determine if there is a fault there
Also check your earth leads as these are often overlooked (leads, connections, etc)
