Paul McPherson Posted August 27, 2023 Posted August 27, 2023 I have just purchased a 65 plate insignia, the high beam does not work, after research it seems the previous owner swapped the bumper and lights from an older model, this seems to be the issue, should of had xeon lights now it does not, can you get a conversion plug in kit for the headlights from xeon to halogen to resolve this issue and not changing the whole front end? Cheers Quote
Vauxhall Owners Club Posted August 27, 2023 Posted August 27, 2023 Going from Xenon to Halogen may be a little difficult as the Xenon lights are self adjusting via suspension links and to fit standard headlights to adjust them for height may be a little difficult but probably not impossible. Also, the Xenon Ballasts carry high voltages so wiring may be an issue Quote
Paul McPherson Posted August 27, 2023 Author Posted August 27, 2023 Thanks for that info, I did try a xeon headlight which plugged straight in but obviously they have a tear duct shape so coukd not fit them to the older style bumper as it was a different shape 1 Quote
David Rhodes Posted January 31, 2024 Posted January 31, 2024 Hi, I've just had my Headlights changed on my Vauxhall Insignia because my offside front light didn't work, now I've had the job done, both Headlights now work but mechanic as said the wrong Headlights were put in, & he said beam does not work, because the mechanic as said it's some kind of coding mechanism, can I get my new Headlights coded Quote
