So, I have a 2014 Mokka 1.4 turbo auto that’s just been in to have a leaky rocker cover fixed where they replaced the gasket and found that the housing for the spark plugs had been destroyed by the oil leak too, all fixed and fine for 8 days and now amber engine light has come on, not sure why not checked fault code yet but noticed this sound from the engine bay in the video attached. Any guesses? I know it needs to go back but is it bad bad?
1 hour ago, Vauxhall Owners Club said:
You will need to get the ECU scanned for store fault codes and this should tell you what the issue is
Thanks, I did, now booked in for Monday. fault with a valve in the evaporation tank!
  • Like 1
