Hi
I have an issue when starting my 2016 Corsa D 1.3 if its a warm day or its been sat at work all day. it will start up but then the revs will drop and the engine will cut out. so i start it up again and will run ok but will stutter as if its going to cut out again but carries on running. starts fine on a cool morning it tends to only happen when the weather is warm. I have put a new fuel filter on to see if that helps but it has not.
Thanks in advance
