Martin Feeney Posted November 27, 2023 Posted November 27, 2023 Can anyone advise on the following problem I have. The LED driving lights have gone on the N/S headlight and I am told this requires a complete new headlight unit. Currently Vauxhall, Hella or anyone else I have tried have one in stock and Hella inform me it will be Feb 2024 before these are manufactured again. Problem is my MOT is about to run out and will fail with the faulty LED running light. I have tried dozens of car dismantlers with no luck. I have found second hand lamps in Germany but the part numbers are different and I don't want to chance paying £700 for the wrong lamp. The Vauxhall part number is 13432958 and Hella number is 1ZT011166-731. The German part numbers are 1ZT011166-721 and GM part number 13426663. Does anyone know if these parts are interchangeable as my car is RHD and the German are LHD. Any help would be appreciated. Quote
D8RCS Posted December 18, 2023 Posted December 18, 2023 Your LED Headlights are only road legal because they are Manufacturer fitted and are sealed units and when any of the lights go then the whole unit has to be replaced. I don't know for sure if the DRL is an MOT failure. RHD and LHD are not inter changeable because the lens are set up to direct the light in a different direction because the need to light up the side of the road they are driving on. 1 Quote
DavieR Posted March 22, 2024 Posted March 22, 2024 I believe that daytime running lights are only part of the mot for cars newer than 2018. https://www.gov.uk/government/news/mot-changes-20-may-2018 Quote
Manchester John Posted May 20, 2024 Posted May 20, 2024 On 11/27/2023 at 6:15 PM, Martin Feeney said: Hella inform me it will be Feb 2024 before these are manufactured again... Expand I have the same problem with my running light, but as you say it does not impact on the MOT. The replacement is eye watering money. I was wondering if my 2016 insignia which is intended to run with these GM13426666 headlamps would work as well on the earlier facelift lamps GM13409908. It would be massively cheaper for me to buy both of these earlier lamps than to replace just one of the new ones. Can I plug and play the earlier version facelift lights or is this a non starter? Quote
D8RCS Posted May 29, 2024 Posted May 29, 2024 I don't have an Insignia so I honestly don't know if earlier facelift lights would be plug and play. May be worth a try on the Facebook Forum also should be able to source cheaper second hand replacements. Quote
Car70Pet Posted July 8, 2024 Posted July 8, 2024 I've just had the same problem with the same part number for a 2014 Insignia. It fails the MOT because the running light doubles as a sidelight and should come on more faintly when you turn the switch from auto to sidelights. Amazing that Vauxhall can't get one and local garages have searched all their suppliers, plus eBay, Trents, etc. and also failed - no solution......... Quote
Car70Pet Posted August 5, 2024 Posted August 5, 2024 ........so the MOT expired and I've had to change the car. If they're not supporting this model any more Vauxhall should come clean and say so, not keep the part on order for months on end, but "out of stock" with no indication when, if ever, it will be supplied again! By the way, in months of looking I've only seen one used come up on eBay and that had red scuff marks on it which I wouldn't have been happy with - and even then it was about £400. Quote
Teeky Posted September 10, 2024 Posted September 10, 2024 Hi with anyone still suffering with this issue I've found a seller one ebay who is selling them https://www.ebay.co.uk/itm/204982567472?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=v2mbS-IlSEq&sssrc=4429486&ssuid=v2mbS-IlSEq&var=&widget_ver=artemis&media=COPY Quote
The Arno Posted November 20, 2024 Posted November 20, 2024 (edited) On 9/10/2024 at 7:40 PM, Teeky said: Hi with anyone still suffering with this issue I've found a seller one ebay who is selling them https://www.ebay.co.uk/itm/204982567472?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=v2mbS-IlSEq&sssrc=4429486&ssuid=v2mbS-IlSEq&var=&widget_ver=artemis&media=COPY Expand BEWARE- These lights are for LEFT Hand Driving - i.e. Europe. They will fail an MOT, The only lights that are valid for the UK are the ones made in SLOVENIA. Check the country the lights are made in first. You can usually see this in the images on Ebay. Edited November 20, 2024 by The Arno Quote
The Arno Posted November 22, 2024 Posted November 22, 2024 IN STOCK TODAY!! BE QUICK https://www.autodoc.co.uk/spares-search?keyword=13432958&_gl=1*66b2m1*_up*MQ..*_gs*NA..&gclid=CjwKCAiA9IC6BhA3EiwAsbltOFDGsjR-EnLlS2UR59Zbr6YTKoBI2VO-uz97XHfOFc2yWdzVyUMKshoCHwYQAvD_BwE Quote
AndyB Posted Sunday at 09:51 AM Posted Sunday at 09:51 AM Just had mine done. Excellent service Quote
