XIIIESQ Posted December 6, 2023 Posted December 6, 2023 My Vauxhall Meriva has suddenly started playing up, I had an intermittent traction and abs light which pointed me to a wheel speed sensor but after around 5 minutes of driving it now comes up with two additional traction/brake lights, the immobiliser light and a freeze on the odometer, the car also gives me an up shift indicator when this happens, even if I’m in 5th and have no more gears to go up! speed still works however the needle does periodically jump but the mileage will not go up during that time. Also worth noting the parking brake will not engage anymore either, you can hear it whirring and doing its thing then hear it immediately releasing with the park brake light on the dashboard flashing and failing to engage. A quick off and on of the ignition while driving clears this up again for around 5 minutes before all the lights return. I have plugged this in on my Autel and it seems to bring up a whole range of electrical problems, hard to believe that they aren’t all related. I’ve attached codes below P0171-00 Fuel trim system lean 1207-00 C1208-00 C1232-00 C1233-00 Electronic brake control module C0040-06 Right front wheel speed sensor circuit - low voltage/open C0035-01 Left front wheel speed sensor circuit short ts battery Parking brake control module C0561-71 Invalid signal received - invalid data Body control module B0000-00 Vehicle speed information circuit - no signal B2523-05 Left rear auto lock switch circuit - high voltage/open 82524-05 Right rear auto lock switch circuit - high voltage/open B252C-05 Left rear child security lock switch - high voltage/open B252F-05 Right rear child security lock switch - high voltage/open B2996-05 Left rear door ajar circuit - high voltage/open C0040-06 Right front wheel speed sensor circuit - low voltage/open C0035-01 Left front wheel speed sensor circuit - short to battery C0050-01 Right rear wheel speed sensor circuit - short to battery C0045-5A Left rear wheel speed sensor circuit - not plausible Electronic power steering control module C0000-71 Vehicle speed information circuit - invalid data U0073-00 Control module communication bus A bus off - malfunction 00100-00 Lost communication with engine control module - malfunction the vehicle is a 2011 Meriva 1.4 Petrol. Any help would be greatly appreciated Quote
Finn Posted December 8, 2023 Posted December 8, 2023 This happened to my meriva 2011 1.4 petrol, it was like Blackpool illumination, car still drove but nothing worked. Pointed to the abs system. It sits under the plastic header tank for topping up the antifreeze. Took it to a guy who fitted a second hand one and reset everything. This might be your problem but mine seems to have worked Quote
