vinniewilkie Posted February 17, 2024 Posted February 17, 2024 hi so i had the water pump changed on my meriva - still getting the car overheating. there was leak previously through the pump i had put rad weld in the system prior to getting the pump changed.now the heaters are not blowing hot air. any ideas/ suggestions very welcome - not mechanically minded at all TIA Quote
Finn Posted February 18, 2024 Posted February 18, 2024 Look at the header tank that you top up the anti freeze , mine was over heating renewing it solve the problem, don’t get from Amazon, I did and wouldn’t fit Quote
Finn Posted February 18, 2024 Posted February 18, 2024 Just now, Finn said: Look at the header tank that you top up the anti freeze , mine was over heating renewing it solve the problem, don’t get from Amazon, the cap I got from Amazon was useless, Quote
