DavidUK Posted February 19, 2024 Posted February 19, 2024 Hi all ! I am owner of Vauxhall Crossland X 2018 automatic gearbox edition , and I trying to get ideas how to drain the transmission on this vehicle. I got the position of drain under the bottom and the filler plug already. but I got a difficulty to get where I can buy gasket replacement after unscrew drain. i am reading Haynes manual and it says Raise the vehicle Remove the level plug Discard the gasket Remove the overflow plug Discard the gasket Drain the automatic transmission So I should have 2 gaskets to replace during drian the transmission fluid. I try type it in Google, find in euro car part, Halfords. All I can get is just Engine oil drain plug replacement , I don’t think it would match ? It is ? look forward for answers, your help I will very appreciated Quote
