DomRhodes Posted April 13, 2024 Posted April 13, 2024 Engine light came on went into limp mode came up with p0299 checked map sensor was fifthly clean it didn't make no difference brought new map sensor worked for 10 mins went back into limp mode with same fault checked air filter incase was dirty no issues there so was thinking might be gas waste exhaust valve.. anyone got any other idea's on issue .. thanks Quote
Vauxhall Owners Club Posted May 14, 2024 Posted May 14, 2024 I would put money on it being the turbocharger variable vanes sticking due to excessive carbon deposits Try using a cleaner to remove the carbon - links below: Wynns JLM Revive Quote
