sarah.h Posted April 21, 2024 Posted April 21, 2024 Hi there, for the last month or so, I can hear the sound of water moving around somewhere to the left of the driver side / front passenger doorway / gear stick area. I’ve had a mechanic look at it and he didn’t see any problems but it’s bugging the life out of. Has anyone else had this problem? Thank you Sarah x Quote
Vauxhall Owners Club Posted May 10, 2024 Posted May 10, 2024 Usually water collects in the scuttle panel area below the windscreen and accessed from the engine bay. If you have a sunroof then sometimes the water can travel down into the area you describe where it should drain out but if the drains are blocked then this may be the reason Quote
