TonyH232 Posted April 21, 2024 Posted April 21, 2024 Hi everyone, this has been driving me up the wall. Symptoms - Pulsing during acceleration, usually around 2k rpm. As far as i can tell my fuel consumption hasn't changed. NO faults codes at all. No other issues during driving. Doesn't stutter or anything like that Fixes I've tried - Changed fuel filter. cleaned EGR. Added diesel clean at almost every refuel. Air filter fine. Boost pipe fine (changed it a years or so ago and took it off again to check) Any guidance would be very much appreciated. I am at a total loss. Quote
John McMahon Posted April 22, 2024 Posted April 22, 2024 Worth checking; I had a Fiat that did the same thing, Long story short it was traced by an auto-electrician to the throttle potentiometer. As you open the throttle the central contact slides along. This differential tells the CPU where the throttle is. In my case it was a broken wire which required some healthy bodge work. BIL had the same issue with his Citroen so you never know HTH. Quote
TonyH232 Posted April 24, 2024 Author Posted April 24, 2024 Thanks John, I had seen something mentioned about the throttle position, but brushed it off as I assumed if that was the issue, it would have the same symptoms at every position. However, I think I'll delve deeper into it and see what I can see. Hope I come back with some good news. Quote
TonyH232 Posted May 14, 2024 Author Posted May 14, 2024 Negative on the potentiometer. Back to square one. Quote
