peterpointer12 Posted May 15, 2024 Posted May 15, 2024 I'm hoping that someone out there can give me some feedback on an intermittent problem I'm having with my Zafira 1.6 Petrol 2010 plate. The car apart from this annoying current issue is in excellent condition for it's year. It starts on the button every-time, the engine is as sweet as a nut ..... no issues with either. The problem I'm having is this : Every now and then there is a large plume of grey/blue smoke coming from the exhaust lasting approx 4/5 secs. This can happen 1/2 times per day every 2/3 weeks. Oil and water have been checked for cross contamination..... none found , also no sign of any oil leaks. Oil light has come on just once and went off again on restarting engine. Hasn't come back on since. It has been put to me by a mechanic that the oil cooler seals are the issue. I'm struggling to work it out how this could be the problem. I would really appreciate any thoughts or feedback . Have you heard of this happening before. Many Thanks for reading . Quote
peterpointer12 Posted May 16, 2024 Author Posted May 16, 2024 17 hours ago, peterpointer12 said: I'm hoping that someone out there can give me some feedback on an intermittent problem I'm having with my Zafira 1.6 Petrol 2010 plate. The car apart from this annoying current issue is in excellent condition for it's year. It starts on the button every-time, the engine is as sweet as a nut ..... no issues with either. The problem I'm having is this : Every now and then there is a large plume of grey/blue smoke coming from the exhaust lasting approx 4/5 secs. This can happen 1/2 times per day every 2/3 weeks. Oil and water have been checked for cross contamination..... none found , also no sign of any oil leaks. Oil light has come on just once and went off again on restarting engine. Hasn't come back on since. It has been put to me by a mechanic that the oil cooler seals are the issue. I'm struggling to work it out how this could be the problem. I would really appreciate any thoughts or feedback . Have you heard of this happening before. Many Thanks for reading . I forgot to mention that the spanner light on the dash comes up just before it starts smoking and sometime later with go off by itself. It has also been known to appear odd times without the smoke......????????? Quote
Vauxhall Owners Club Posted May 28, 2024 Posted May 28, 2024 Grey/Blue smoke could be oil being burnt....valve seals possibly. Does the smoke smell of oil? Does it occur when hot or cold? Quote
