Freki Posted May 23, 2024 Posted May 23, 2024 I have had this warning light on for months - garage has looked at it and found nothing obvious. They clear it and it comes back after a few days. We assumed it was EGR-related. So van was finally booked in. Van broke down on the M6. Van relayed to garage and they replaced (both? - i didn't know it had 2) EGR valves and also turbo was knackered. £2300 later, van drives out, working fine then 250 miles down the road, same error message comes back. In addition - coolant loss is constant. No leaks visible. Pressure test passed. UV dye used - nothing seen. No coolant in oil. No steam in exhaust. Typically 1/2 litre of coolant needed every 100 miles to top up to expansion tank level - if i do a long drive and forget to top it up on way home, i get "engine Stop".. so i fill it up and away we go. I have no garage who seems to know what is wrong and i cannot afford to keep spending money on it, on the off-chance they find something. Looking online, others seem to have similar issues but no solution is ever published. Any help at all from anyone on either issue - are they related? Many thanks in advance Quote
James12 Posted August 18, 2024 Posted August 18, 2024 Any luck with this? I’ve been having the same problem and can’t find the issue. Quote
