Greetings! I'm trying to access the body control unit behind the glove box of my 2014 Meriva B. I was able to find the 2 screws at the top and remove them. I also found the 3 push fasteners along the bottom edge and removed the plastic panel behind. But the box still will not come out. Feels as though there are more fasters but I can't find them. Anyone able to help? I'd be much appreciative.
12 hours ago, FRONTERATECH said:
a video on you tube for changing the pollen filter quite good you have to remove trim at side of centre console and the dash panel to remove
THANK YOU Fronteratech! Quick job when you know what to do. Had it out in 5 minutes. Many thanks!
