Peter8989 Posted August 17 Share Posted August 17 So I have code 68 on meriva b 1.4 2013. Power steering light and traction control light on. Changed power steering pump and no change light still on. Also a coolant leak onto and pump. My thoughts are could it be a dodgy power steering module? Any help welcomed as it’s becoming a money pit. Quote Link to comment Share on other sites More sharing options...
FRONTERATECH Posted August 17 Share Posted August 17 have you cleared the codes after new power steering pump fitted. traction contro, would relate to abs module in similar area Quote Link to comment Share on other sites More sharing options...
Peter8989 Posted August 18 Author Share Posted August 18 Codes won’t delete and says many things are wrong including electronic handbrake. Quote Link to comment Share on other sites More sharing options...
FRONTERATECH Posted August 21 Share Posted August 21 check for water ingress on the ABS module the expansion tank is above it sometimes leaks onto the module disconnect plug clean connector as the wires to power steering also go to ABS 1 Quote Link to comment Share on other sites More sharing options...
Peter8989 Posted August 21 Author Share Posted August 21 Done that ended up replacing steering angle and steering sensor which sorted the problem. Turn ignition on and full lock it and code 68 pops back on. Turn car off and it’s gone. Quote Link to comment Share on other sites More sharing options...
FRONTERATECH Posted August 22 Share Posted August 22 sounds like new pump at fault was it recon or new Quote Link to comment Share on other sites More sharing options...
