  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
My wife drove off with the rear nearside door still open - it caught another parked car and was forced all the way back against the car body! See images for the resulting damage 😲
I've been advised that I need to find a replacement door and hinges so it can be put on to check that the underlying bodywork isn't damaged.
My question relates to our car having electronic windows in the rear, but some replacements I've found have manual windows. Are the two compatible? I assume it may be possible to remove the motor and move it across, plus use the door card from my existing door for controls etc, but will all the cutouts for the cables be present? Are the two compatible?
Thank you for any knowledge in advance.
tezza73uk
