1micky2 Posted September 14 Share Posted September 14 Hi Guys help needed my Daughter Recently bought a 2014 1.2 Corsa the problem is the heater fan has stopped working could you tell me where the fuse is or is there something else to look out for Thanks Quote Link to comment Share on other sites More sharing options...
Vauxhall Owners Club Posted Tuesday at 01:00 PM Share Posted Tuesday at 01:00 PM if the fan is working on the highest speed then it is a faulty resistor pack which alters the fan speed If not working at all then more than likely the motor....try thumping it from under the dash when the blower is switched on and if working then brushes are worn out and need new motor...cheap and relatively easy to fit Quote Link to comment Share on other sites More sharing options...
