scm924s Posted November 5, 2024 Posted November 5, 2024 Anyone had problems with engine coolant temperature struggling to get of the bottom of the gauge? In normal running around town the pointer stays resolutely on the bottom stop, only after about a 12/15 mile drive does it eventually approach the 90deg mark. As a result the cabin heater is pretty inneffective. A reasonably informed guess by me (a lifetime classic car owner) suggests a thermostat fail, which on my classics is a £10 and hours job. A search on line seems to indicate that the Crossland thermostat is a comprehensive assemblage at around £120. and as far as I can tell is hidden under the inlet manifold, so much for progress! Booked to go into the local stealers next week, not looking forward to the eventual bill, unless anyone has some helpful suggestions. 1 Quote
Vauxhall Owners Club Posted November 8, 2024 Posted November 8, 2024 It may be the gauge is not too accurate rather than an issue with the engine temperature failing to get to the normal operating temperature. I would personally invest in an infra-red temperature gun (circa £20) and measure different parts of the engine as it heats up and then you'll know whether there is a fault (stuck thermostat) or whether the gauge is just there for effect Quote
scm924s Posted November 8, 2024 Author Posted November 8, 2024 I think if it were a faulty gauge, the cabin heating would not be struggling to get past luke warm.Until very recently car has reached operating temperature very quickly together with a toasty heater. Quote
scm924s Posted November 16, 2024 Author Posted November 16, 2024 Car spent all day at local Stealers, had a full diagnostic check, and reported that everything is OK!! Car still will not achieve normal operating temperature of 90 deg! Words fail me Quote
scm924s Posted November 29, 2024 Author Posted November 29, 2024 Just to write a conclusion to this. It was apparent to me, if not the local Vx dealer, that the thermostat had failed in the open position, this was confirmed by a local garage recommended to me. He replaced the thermostat and housing unit at a cost of about £340 of which the thermostat was £135 (( a complex bit of kit) and coolant about £20 plus a couple of hours labour and I was well pleased. Coolant temperature back to a steady 90deg and decent heating. Why these modern engines are so complicated beats me, on my 40 year old Porsche a replacement thermostat is about £15 and it's about an hours work for me to replace it. The price of progress!!! I 1 Quote
Vauxhall Owners Club Posted December 9, 2024 Posted December 9, 2024 Thanks for providing us with feedback and helpful for any members who are in the same situation. Cannot believe the dealers didn't pick up on this, but always good to know a decent independent garage who can solve issues like this Quote
