duggie Posted December 3, 2024 Posted December 3, 2024 Hi been a while since being on here any way lot of conflicting advise about the repair of these High pressure pumps. I fitted a repair kit on my HPP and filled with ATF ran for 2 weeks but with no fast acceleration ( kick down ) but was told that ATF expands and blows seals so i drained the ATF a filled with 75w90 semi ( recommended ) 2 days later i had to boot it (kick down ) spanner light limp mode so i stripped pump and oil seal was forward of shaft and the 3 round seals had pieces missing. Now was this due to the ATF expansion or overfill of the 75w90 oil or both.So now the question is what is the best / correct oil and how much i/e fill bleed then press button to expel excess oil if pressed to much will it empty all the oil out also how to keep the 3 round disc sitting in the correct position on reassembly bit of grease thanks for any info Quote
