Gizmo26 Posted December 6, 2024 Posted December 6, 2024 New here,Looking for some help and advice here on my 55 plate veccy 1.8sri. Bought the car a few months ago, had intermittent ciggy lighter usage for dash cam/changing phone since I bought it on both fronts and rear ciggy lighters. So I'm assuming it's a dying fuse but I wouldn't know where to start. Also last night my front wipers stopped working. The motor still makes a noise but wipers won't move, rear one works fine it's just the front 2. Also passenger front window can only be opened/closed by drivers controls would it be a simple fix with a new switch? This is my first owned car since iv stopped getting mobility cars and would like to do as much work as I could myself before resorting to taking it to a garage so any and all advice etc is very much welcomed. Quote
Vauxhall Owners Club Posted December 9, 2024 Posted December 9, 2024 Sounds like it could be the fuse is slightly loose in the fusebox but more likely wiring issue. The wipers sounds like the linkage has detached itself and would need to remove the arms and plastic panel to access the linkage to reattach or replace it More than likely is the window switch or wiring to the door that is the issue Quote
