MarkF Posted January 21 Posted January 21 No photo. I think the locking pin is jammed or corroded. Quote
Vauxhall Owners Club Posted January 28 Posted January 28 Check fuse 20 to see if that is blown - usual fault is the actuator mechanism is seized and will need cleaning up or replacing You can manually release the catch by removing the drivers side rear side trim cover in the boot area and moving the mechanism by hand Quote
