Devonlad85 Posted January 26 Posted January 26 Hi guys hope someone can help me. Driving my 2.0cdti tourer the clutch pedal went soft and really struggle to change gears. After pumping the clutch pedal few times the pressure came back but the brake fluid reservoir was low. Anyone had this problem before. Any information would be appreciatedĀ Quote
Vauxhall Owners Club Posted January 28 Posted January 28 Sounds like you have a leaking slave or master cylinder (or both) if the fluid needs topping up Best to look underneath and see if there are any fluid leaks in the transmission area Quote
adam.culyer Posted March 31 Posted March 31 i had this same problem it turned out to be the slave cylinder 1 Quote
