Hi All
Looking for help.  My 60 plate Zafira 1.8 SRI Zafira B is acting up and I need help.
The Power Steering went so its had the Power Steering Pump changed for a new one, now every time I start the car its steering by itself (does a full circle by itself) and also its trying to over steer/steering its self around corners (find myself fighting it to pull it back) its fine on the straight apart from the steering wheel also now being slightly off center.  Oh and the steering lock won't click in now either.  Obviously its off road because of the above.
What do you recommend, do I need to change the steering column and the electrics behind or is there something else I can do.
I know some of you might say "maybe its time to get rid" but I can't bear to loose her just yet.  There must be a reasonably simple fix.
Please explain in layman's terms and thanks for any help.
