florinbr Posted March 9 Posted March 9 Hello my friend I have a 57 reg vectra c gasoline z18xer and i have this problem whith my thermostat P0597-61 Coolant Thermostat Valve Stuck. I change 3 thermostat and body of thermostat and still same problem. At 95° the fan should open but i dont reach this themperature because the coolant is geting out is overheating and blow it outside. On the body of thermostat is a sensor if i take the plug fan is running. Down on radiator is another sensor if i take the plug i found a error open circuit. I use opcom and think diag . I dont no what to do next. Can you help me ??? Quote
